Zum Hauptinhalt wechseln
Canon PowerShot A590 IS Memory Card Replacement
Zach
Zach und 5 weitere Mitwirkende
Zuletzt aktualisiert am March 19, 2020
5 Minuten
Sehr einfach
Fehlende Schritte
This guide will instruct the user on how to open the bottom hatch to access the batteries and memory card, and to remove and replace the memory card.
  1. Canon PowerShot A590 IS Memory Card Replacement, Open the Battery Hatch: Schritt 1, Bild 1 von 1
    • Be gentle with the hatch, it is fragile.
    • *See battery replacement guide for help opening the hatch.
  2. Canon PowerShot A590 IS Memory Card Replacement, Locate Memory Card: Schritt 2, Bild 1 von 1
    • The memory card slot is shown here in the red rectangle.
  3. Canon PowerShot A590 IS Memory Card Replacement, Remove Memory Card: Schritt 3, Bild 1 von 1
    • To eject your memory card, simply press it into the camera gently, and it will spring out.
    • After it has been released from the camera, just pull it out.
  4. Canon PowerShot A590 IS Memory Card Replacement, Replace Memory Card: Schritt 4, Bild 1 von 1
    • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
    • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Zach
284 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-19, Regan Fall 2010 Mitglied von Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 5,680
