Canon PowerShot A75 Casing Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the Canon Powershot A75's casing.
Was du brauchst
Open the memory card slot by sliding it laterally until you hear a click.
Remove the 5.9mm screw in the upper corner of the memory card slot.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
On the front of the camera, press the button on the lower left of the lens.
Twist the outer lens casing counter-clockwise and slide it out.
4 weitere Personen haben diese Anleitung absolviert.
