Canon PowerShot G12 Rear Function Setting Dial Replacement
Einleitung
Zu Schritt 1 der AnleitungReplacing the function dial is a highly-invasive, step-intensive process that becomes necessary if the function dial has sustained damage due to a crack or internal malfunction.
The function dial refers to the round mechanism on the lower back side of the camera identified by "Func. Set." In this guide, you will learn how to replace the function dial carefully without damaging any essential internal components.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
Remove the one screw on the side of the HDMI port.
Remove the screw on the right side of the view finder on the back side of the camera.
Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
Put the camera aside and look to the interior to the camera's back shell.
Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
