Zum Hauptinhalt wechseln
Canon PowerShot SX160 IS Shutter Button Replacement
Jamie Secretan
Jamie Secretan und eine weitere beteiligte Person
Zuletzt aktualisiert am June 22, 2015
15 - 30 Minuten
Mittel
This guide walks you through how to replace a shutter button on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
Was du brauchst
Werkzeuge
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: Schritt 1, Bild 1 von 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: Schritt 1, Bild 2 von 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: Schritt 1, Bild 3 von 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Shutter Button Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SX160 IS Shutter Button Replacement: Schritt 2, Bild 2 von 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot SX160 IS Shutter Button Replacement: Schritt 3, Bild 2 von 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: Schritt 4, Bild 1 von 1
    • Locate and replace the shutter button on the front panel of the camera.
Abschluss
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
Jamie Secretan
1.990 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Mitglieder
2 Kommentare
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Antwort
did you ever figure out where to get a new button?
christinapayne1@icloud.com -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 3,072
