Canon Powershot A3300 IS Back Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungIf you have broken the back cover to your camera or it is worn out this guide will show you how to replace it.
Was du brauchst
Werkzeuge
Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
