Zum Hauptinhalt wechseln
Canon Powershot A3300 IS LCD Display Replacement
Kenny Chui
Kenny Chui und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 - 15 Minuten
Schwierig
Falsche Werkzeuge
This guide will show you how to replace a broken or malfunctioning LCD display.
Was du brauchst
  1. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: Schritt 1, Bild 1 von 3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: Schritt 1, Bild 2 von 3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS LCD Display Replacement: Schritt 2, Bild 1 von 2 Canon Powershot A3300 IS LCD Display Replacement: Schritt 2, Bild 2 von 2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS LCD Display Replacement, Front Cover: Schritt 3, Bild 1 von 2 Canon Powershot A3300 IS LCD Display Replacement, Front Cover: Schritt 3, Bild 2 von 2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS LCD Display Replacement, LCD Display: Schritt 4, Bild 1 von 1
    • Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
  5. Canon Powershot A3300 IS LCD Display Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the LCD screen off the back of the camera.
  6. Canon Powershot A3300 IS LCD Display Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to pull out the circled brown flat flexible wire from its connection.
  7. Canon Powershot A3300 IS LCD Display Replacement: Schritt 7, Bild 1 von 2 Canon Powershot A3300 IS LCD Display Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to reach under the connecting wire.
    • Gently slide the spudger under the wire and lift the wire off the connection.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kenny Chui
122 Reputation
1 Anleitung geschrieben
UC Santa Barbara, Team S2-G7, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S2-G7, Weedon Fall 2017
UCSB-WEEDON-F17S2G7
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 804
