Canon Powershot SX30 IS Back Camera Housing Replacement
Einleitung
Zu Schritt 1 der AnleitungQuick guide on removing and replacing the plastic back cover. Replacement is required if the functions buttons fail to work, or the casing has been damaged.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Position the camera so that the right side is visible as shown.
Unscrew the two 6 mm screws shown using a screwdriver.
Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
Then, unscrew the lone 6mm screw that was under the plastic flap.
Turn the camera so that the bottom is visible, as shown.
Unscrew the three 4mm screws shown red using a screwdriver.
Unscrew the single 6mm screw.
Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
Turn the camera so the back side is visible, as shown.
Unscrew the two 6mm screws.
Detach the wire by lifting the small black bar that holds it to the main body of the camera.
2 weitere Personen haben diese Anleitung absolviert.
