Zum Hauptinhalt wechseln
Carlo Robelli CBW-4134CR Piezo Pickup Replacement
Bryant Castor
Bryant Castor und eine weitere beteiligte Person
Zuletzt aktualisiert am June 3, 2022
20 - 30 Minuten
Mittel
This guide was created to help replace the piezo pickup on a Carlo Robelli Acoustic guitar (CBW-4134CR). This guitar was converted to an acoustic-electric guitar by installing a preamp (EQ-7545R), which was found on Amazon after the original piezo pickup installed was not giving out an output signal or in other instances sounding poor in quality. The piezo pickup is connected to the guitar preamp's input and placed under the bridge saddles to pick up the strings' vibrations. A faulty pickup can lead to feedback noise, loud buzzing, or sometimes no signal after plugging in a 1/4 inch cable into the guitar's output. It is best to follow this guide by placing the guitar on a flat and level surface so that the guitar does not fall and break or so that the guitar pins do not roll off and get lost. This guide may help any guitar with a piezo pickup, but the steps may not be the same.
  1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 3 von 3
    • Unwind the low E guitar tuner with a guitar winder to loosen the string.
    • Cut the string above the sound hole using a string cutter.
  2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 3 von 3
    • Remove the low E string from the guitar tuner and remove the bridge pin.
  3. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 3 von 3
    • Repeat Steps 1 and 2 for the rest of the guitar strings, removing all the pins and strings.
    • Remove the bridge saddle.
  4. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 3 von 3
    • Find the preamp box inside the guitar soundhole and disconnect the piezo pickup only.
  5. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 3 von 3
    • Inside the guitar, find the piezo pickup and push outward.
    • Once the pickup is sticking out, pull to remove it.
  6. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 3 von 3
    • Grab the new piezo pickup and insert it in the designated hole, pressing firmly and ensuring it is neatly tucked in.
  7. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 3 von 3
    • Once the piezo pickup is inside the guitar, connect the pickup to its proper input inside the guitar preamp.
  8. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 3 von 3
    • Place the bridge saddle back in place.
    • Insert a new set of strings with guitar pins to ensure that the line is not pulled out when winding the new guitar strings.
  9. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 3 von 3
    • Once all new strings are wound up, cut off the excess line for a neater look.
  10. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 10, Bild 1 von 1
    • This is how the bridge should look once everything is back into place.
Abschluss
Having a new piezo pickup will heavily improve the sound quality sent from your guitar to the guitar amplifier, recording interface, PA system, or headphones.
Bryant Castor
181 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-88, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 8-88, Briggs Spring 2022
CSULA-BRIGGS-S22S8G88
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 449
