Zum Hauptinhalt wechseln
Casio CZ-1000 Piano Key Replacement
CJ Fagundo
CJ Fagundo und eine weitere beteiligte Person
Zuletzt aktualisiert am January 2, 2025
15 Minuten
Leicht
This guide is to replace a damaged or broken piano key on your Casio CZ-1000 synthesizer. A broken piano key can cause the key to feel loose or be unresponsive.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Casio CZ-1000 Piano Key Replacement, Backplate: Schritt 1, Bild 1 von 2 Casio CZ-1000 Piano Key Replacement, Backplate: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Piano Key Replacement: Schritt 2, Bild 1 von 3 Casio CZ-1000 Piano Key Replacement: Schritt 2, Bild 2 von 3 Casio CZ-1000 Piano Key Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Piano Key Replacement: Schritt 3, Bild 1 von 3 Casio CZ-1000 Piano Key Replacement: Schritt 3, Bild 2 von 3 Casio CZ-1000 Piano Key Replacement: Schritt 3, Bild 3 von 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Piano Key Replacement, Piano Key: Schritt 4, Bild 1 von 2 Casio CZ-1000 Piano Key Replacement, Piano Key: Schritt 4, Bild 2 von 2
    • Remove the four 7.5 mm screws using a Phillips #1 screwdriver.
    • Lift the rectangular circuit board away to expose the underside of the key bed.
  5. Casio CZ-1000 Piano Key Replacement: Schritt 5, Bild 1 von 2 Casio CZ-1000 Piano Key Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 7.5 mm screws using a Phillips #1 screwdriver.
  6. Casio CZ-1000 Piano Key Replacement: Schritt 6, Bild 1 von 2 Casio CZ-1000 Piano Key Replacement: Schritt 6, Bild 2 von 2
    • Grab the key bed by the side shown.
    • Lift the key bed up and slide it out from the black case.
  7. Casio CZ-1000 Piano Key Replacement: Schritt 7, Bild 1 von 2 Casio CZ-1000 Piano Key Replacement: Schritt 7, Bild 2 von 2
    • Flip the key bed over so that the keys are facing up.
    • Using a pair of tweezers, detach the spring from both the metal bar and the key itself.
    • Lift the key out of the slot in the metal bar and replace!
Abschluss
CJ Fagundo
159 Reputation
1 Anleitung geschrieben
Cuesta, Team 60-3, Krynen Fall 2024 Mitglied von Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Disassembly went fine, but my cz1000 keys don't look the same
Brian Marshall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 62
