Cleaning the Fan Blades
Einleitung
Zu Schritt 1 der AnleitungThis guide will disassemble the fan to clean the fan blades.
Was du brauchst
Werkzeuge
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
Remove the screws from the four corners of the circuit board.
Remove the circuit board from the top cover.
Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
Use a cloth to clean off dust clogged in between the fan blades.
Eine weitere Person hat diese Anleitung absolviert.
