Zum Hauptinhalt wechseln
Cricut Explore Air 2 Roller Bar Motor Replacement
Hannah Vanvlack
Hannah Vanvlack und eine weitere beteiligte Person
Zuletzt aktualisiert am May 22, 2024
10 - 20 Minuten
Leicht
If you need to replace the roller bar motor, use this guide to access it. If the roller bar begins to malfunction or stops rolling altogether, the motor could be the cause. For this repair, you will need Phillips #1 and #2 screwdrivers or screwdriver bits. There are no difficult steps, but some are delicate and require particular care and attention.
Was du brauchst
Werkzeuge
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: Schritt 1, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: Schritt 1, Bild 2 von 2
    • With the Cricut open, access the two internal screws on the front left side.
    • Use the Phillips #1 screwdriver to remove the top 10.82 mm screw and the bottom 9.1 mm screw.
  2. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 2, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 2, Bild 2 von 2
    • Rotate the Cricut so the bottom is facing upwards.
    • Identify the two screws with pads.
    • Using the Phillips #2 screwdriver, remove both 42.77 mm screws.
  3. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 3, Bild 1 von 1
    • Rotate the Cricut back to its upright position.
    • Gently lift the cover on the left side of the machine to reveal the parts underneath.
  4. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 4, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 4, Bild 2 von 2
    • Locate the circuit board on the cover just removed.
    • Use the Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  5. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 5, Bild 1 von 1
    • Gently unplug the connector, removing the circuit board.
  6. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 6, Bild 1 von 1
    • Gently unplug the connector located on the roller bar motor.
  7. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 7, Bild 1 von 1
    • Locate the three screws securing the plate holding the roller bar motor to the Cricut.
    • Use the Phillips #1 screwdriver to remove each of the three 5 mm screws.
  8. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the motor from the interior of the Cricut.
  9. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the white gear from the roller bar motor.
  10. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 10, Bild 1 von 1
    • Locate the two screws holding the roller bar motor to the mounting plate.
    • Use the Phillips #1 screwdriver to remove the two 2 mm screws.
  11. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 11, Bild 1 von 1
    • Remove the motor from the plate.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 318
