Zum Hauptinhalt wechseln
Dell Inspiron 13-7347 Battery Replacement
lee120496
lee120496 und 5 weitere Mitwirkende
Zuletzt aktualisiert am February 16, 2025
10 Minuten
Leicht
This guide would be useful for replacing faulty or broken battery for your Dell Inspiron 13-7347. Before you get started, please pay attention to few notes. 1)Make sure the battery that you are replacing is specifically for Dell Inspiron 13-7347. There are rumors that some of the batteries are universal as long as they are within the same company. It would be safe if you can find an exact matched battery from Dell Inspiron 13-7347 in order to prevent any troubles. 2) Be sure to use the tools we suggested, and be gentle when you are using the screwdriver. Its very easy to lead to stripped screws if you didn't use the screwdriver correctly or not gentle enough.
Make sure to follow the instructions step by step carefully.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 13-7347 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7347 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7347 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 3, Bild 3 von 3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 13-7347 Battery Replacement: Schritt 4, Bild 3 von 3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
Abschluss
lee120496
643 Reputation
4 Anleitungen geschrieben
UC Davis, Team S20-G8, Lore Winter 2019 Mitglied von UC Davis, Team S20-G8, Lore Winter 2019
UCD-LORE-W19S20G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 20
Insgesamt: 911
