Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 1 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 2 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 3 von 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 5, Bild 1 von 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Chase Sparkman
512 Reputation
2 Anleitungen geschrieben
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
4 Kommentare zur Anleitung
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Antwort
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Antwort
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Antwort
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 3,468
