Zum Hauptinhalt wechseln
Dell Inspiron 13-7359 Battery Replacement
Valentin Medina
Valentin Medina und 2 weitere Mitwirkende
Zuletzt aktualisiert am April 20, 2018
2 - 5 Minuten
Leicht
This guide will show you how to replace your device's battery without any hiccups. You will need one Phillips #0 screwdriver and one plastic spudger.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: Schritt 2, Bild 1 von 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13-7359 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13-7359 Battery Replacement: Schritt 3, Bild 3 von 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 13-7359 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 13-7359 Battery Replacement: Schritt 4, Bild 3 von 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Baylor, Team S1-G6, Johnson Spring 2018 Mitglied von Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 21
Insgesamt: 1,665
