Dell Inspiron 13-7359 WLAN Adaptor Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace your WLAN adaptor. You will need a Phillips #0 screwdriver and a plastic opening tool to complete this guide.
Was du brauchst
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
With a plastic spudger, carefully remove the back panel by prying each corner off individually
Slowly pick up the panel and set it aside
The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
To remove the old battery, slightly lift the bottom edge of the battery with your hands
Now slowly pull the battery towards you to fully detach the battery
Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
Once the screw is removed, one end of the WLAN adaptor will raise up.
