Zum Hauptinhalt wechseln
Dell Inspiron 13-7373 Fan Replacement
Kameron Jusseaume
Kameron Jusseaume und 5 weitere Mitwirkende
Zuletzt aktualisiert am July 22, 2020
2 - 5 Minuten
Leicht
Use this guide to replace a malfunctioning fan in your Dell Inspiron 13-7373.
Having a fan in a laptop is extremely important because the fan reduces the device's operating temperature which both limits heat exposure to the hardware and allows the device to operate in a stable condition.
A common problem that would require a replacement is when the fan blades stop working due to dust and dirt accumulation. This can often be determined if the fan is making loud and unusual noises as the computer is running. Another method to determine the malfunction is by putting your hand into the heat sink on the laptop side and feel whether there is heat, airflow is being pushed out. If you don't feel the hot airflow from your laptop, take appropriate precautions to cool down your laptop. Bear in mind that, overheating can result in regular laptop crashes and freezing.
Before you begin to replace the fan make sure:
  • you find the appropriate fan for the device because not all kinds of fans work on all devices.
  • to power off the laptop and disconnect it from any external power source.
Be sure to pay attention to all of the steps and use the right equipment during the replacement process.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: Schritt 2, Bild 1 von 1
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: Schritt 3, Bild 1 von 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
Abschluss
To reassemble your device with the new fan, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - Antwort
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 28
Insgesamt: 1,297
