Zum Hauptinhalt wechseln
Dell Inspiron 13-7373 Keyboard Replacement
Kameron Jusseaume
Kameron Jusseaume und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 18, 2023
15 - 30 Minuten
Schwierig
Benötigt Mehr Bilder
Fehlende Schritte
A Dell Inspiron 13-7373 may require a keyboard replacement for several reasons, such as broken keys, physical issues, debris or broken pieces, unresponsiveness, and connection problems. If you use a laptop the majority of your time, it is important to make sure it is comfortable to use and that you get the most out of your keyboard. Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Keyboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Keyboard Replacement, Fan: Schritt 5, Bild 1 von 1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Keyboard Replacement, Network Card: Schritt 7, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Keyboard Replacement, Daughterboard: Schritt 8, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Keyboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 11, Bild 3 von 3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Gently lift up on the motherboard to remove it.
  13. Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: Schritt 13, Bild 1 von 2 Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: Schritt 13, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the eight 1mm screws at the back of the keyboard.
    • Remove the 3 screws holding the hinges of the laptop on each side.
  14. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Lift up on the hinges that the three screws were removed from.
    • They are difficult to move and may require a tad bit more effort.
  15. Dell Inspiron 13-7373 Keyboard Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 13-7373 Keyboard Replacement: Schritt 15, Bild 2 von 2
    • Gently remove the keyboard from beneath the hinges that were lifted up.
Abschluss
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 63
Insgesamt: 1,793
