Zum Hauptinhalt wechseln
Dell Inspiron 14-7437 Coin Cell Battery Replacement
Katelyn Remy
Katelyn Remy und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 4, 2018
7 Minuten
Leicht
The Coin-Cell Battery is a power source for the motherboard while the computer is off. It is used to keep track of the system clock.
Was du brauchst
Werkzeuge
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
Mehr anzeigen …
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 2, Bild 2 von 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: Schritt 8, Bild 1 von 1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: Schritt 9, Bild 2 von 2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Katelyn Remy
449 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 7-8, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 21
Insgesamt: 1,406
