Dell Inspiron 14-7437 Cooling Fan Replacement
Einleitung
Zu Schritt 1 der AnleitungThe Cooling fan is used to remove heat from the laptop so it is not hot to the touch and does not burn the motherboard.
Was du brauchst
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Pry open the back cover using a spudger and slide it along the under the cover.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
