Zum Hauptinhalt wechseln
Dell Inspiron 14-7437 Speaker Replacement
Katelyn Remy
Katelyn Remy und 3 weitere Mitwirkende
Zuletzt aktualisiert am August 8, 2019
6 Minuten
Leicht
if the speaker is not playing sounds properly or liquid is spilled into the speaker gap in the frame of your laptop it is easy and simple to replace them.
Was du brauchst
Werkzeuge
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
Mehr anzeigen …
  1. Dell Inspiron 14-7437 Speaker Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Inspiron 14-7437 Speaker Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Speaker Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14-7437 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Speaker Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Inspiron 14-7437 Speaker Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Speaker Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 14-7437 Speaker Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 14-7437 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the speakers from the case.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Katelyn Remy
449 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 7-8, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 1,125
