Dell Inspiron 14-7437 Speaker Replacement
Einleitung
Zu Schritt 1 der Anleitungif the speaker is not playing sounds properly or liquid is spilled into the speaker gap in the frame of your laptop it is easy and simple to replace them.
Was du brauchst
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Pry open the back cover using a spudger and slide it along the under the cover.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
