Zum Hauptinhalt wechseln
Dell Inspiron 1420 Disassembly
Braxton Quillin
Braxton Quillin und 2 weitere Mitwirkende
Zuletzt aktualisiert am November 21, 2024
45 Minuten - 1 Stunde
Mittel
Anleitung eines Community-Mitglieds
This guide shows how to fully extract the Dell Inspiron 1420 Motherboard.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 1420 Disassembly, Remove Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove Battery: Schritt 1, Bild 2 von 2
    • Press both indicated locks on the bottom side of the laptop to release and remove the battery.
  2. Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: Schritt 2, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: Schritt 2, Bild 2 von 2
    • Loosen and remove indicated screws on the back panel using a Phillips #1 screwdriver.
    • Back cover screws
    • These screws are a different length than the others and can be stored separately for reassembly.
    • Hard drive cover screws
    • RAM cover screws
    • CD drive cover screw
    • Heat sink cover screws
  3. Dell Inspiron 1420 Disassembly, Remove Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the hard drive cover.
    • Pull the tab in the direction of the arrows to remove the hard drive.
  4. Dell Inspiron 1420 Disassembly, Remove CD Drive: Schritt 4, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove CD Drive: Schritt 4, Bild 2 von 2
    • Using a screwdriver, slide out the CD drive bracket enough for it to be grabbed.
    • Remove CD drive from housing.
  5. Dell Inspiron 1420 Disassembly, Remove RAM: Schritt 5, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove RAM: Schritt 5, Bild 2 von 2
    • Remove RAM cover.
    • Pull the metal tabs above and below the RAM outward and remove both RAM sticks.
  6. Dell Inspiron 1420 Disassembly, Remove Heat Sink: Schritt 6, Bild 1 von 3 Dell Inspiron 1420 Disassembly, Remove Heat Sink: Schritt 6, Bild 2 von 3 Dell Inspiron 1420 Disassembly, Remove Heat Sink: Schritt 6, Bild 3 von 3
    • Remove the heat sink cover.
    • Using a Phillips #1 screwdriver, loosen and remove screws from heat sink.
    • Remove the heat sink.
  7. Dell Inspiron 1420 Disassembly, Remove CPU: Schritt 7, Bild 1 von 3 Dell Inspiron 1420 Disassembly, Remove CPU: Schritt 7, Bild 2 von 3 Dell Inspiron 1420 Disassembly, Remove CPU: Schritt 7, Bild 3 von 3
    • Using a flathead screwdriver, quarter turn the screw anticlockwise to release the CPU.
    • Gently lift the CPU out of the housing.
    • The pins on the bottom of the CPU are very fragile and will not function if any are bent.
  8. Dell Inspiron 1420 Disassembly, Remove Bracket: Schritt 8, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove Bracket: Schritt 8, Bild 2 von 2
    • Using a Phillips #1 screwdriver, unscrew and remove bracket.
    • There may be a card along with the bracket in your machine. If there is, unplug and remove this card as well.
  9. Dell Inspiron 1420 Disassembly, Remove Back Screws: Schritt 9, Bild 1 von 1
    • Using a Phillips #1 screwdriver, loosen and remove the indicated screws.
  10. Dell Inspiron 1420 Disassembly, Pry Control Panel: Schritt 10, Bild 1 von 1
    • Use a spudger to pry off the control panel.
  11. Dell Inspiron 1420 Disassembly, Pry Hinge Covers: Schritt 11, Bild 1 von 1
    • Use a spudger to pry off the hinge covers.
  12. Dell Inspiron 1420 Disassembly, Remove Keyboard Screws: Schritt 12, Bild 1 von 1
    • Using a Phillips #1 screwdriver, loosen and remove the keyboard screws.
  13. Dell Inspiron 1420 Disassembly, Remove Keyboard: Schritt 13, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove Keyboard: Schritt 13, Bild 2 von 2
    • Gently lift keyboard to reveal blue ribbon connection.
    • Use a spudger to flip the blue ribbon lever and release the keyboard.
  14. Dell Inspiron 1420 Disassembly, Remove Wifi-Card: Schritt 14, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove Wifi-Card: Schritt 14, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the screw holding in the Wi-Fi card.
    • Unplug cables connected to Wi-Fi card.
    • Slide Wi-Fi card out of connection to remove.
  15. Dell Inspiron 1420 Disassembly, Lift Control Panel: Schritt 15, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Lift Control Panel: Schritt 15, Bild 2 von 2
    • Using a Phillips #1 screwdriver, loosen and remove control panel screw.
    • Carefully pull up control panel. Being sure to keep the cable attached, set to the side.
  16. Dell Inspiron 1420 Disassembly, Remove Monitor: Schritt 16, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Remove Monitor: Schritt 16, Bild 2 von 2
    • Pull the blue tab up to release the monitor.
    • Remove monitor.
  17. Dell Inspiron 1420 Disassembly, Remove Screws: Schritt 17, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove remaining screws from cover panel.
  18. Dell Inspiron 1420 Disassembly, Unplug Connections: Schritt 18, Bild 1 von 3 Dell Inspiron 1420 Disassembly, Unplug Connections: Schritt 18, Bild 2 von 3 Dell Inspiron 1420 Disassembly, Unplug Connections: Schritt 18, Bild 3 von 3
    • Using a spudger, disconnect control panel motherboard cable.
    • Using a spudger, flip up blue lever and disconnect touchpad cable.
  19. Dell Inspiron 1420 Disassembly, Remove Screws and Connections: Schritt 19, Bild 1 von 1
    • Lift off cover panel.
    • Using a Phillips #1 screwdriver, loosen and remove screws from motherboard.
    • Disconnect the indicated cables from the motherboard.
  20. Dell Inspiron 1420 Disassembly, Remove SIM Board: Schritt 20, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove screw.
    • Disconnect indicated cable and remove SIM board.
  21. Dell Inspiron 1420 Disassembly, Remove Memory Card Holder: Schritt 21, Bild 1 von 1
    • Slide memory card holder out of housing.
  22. Dell Inspiron 1420 Disassembly, Remove Modem Card: Schritt 22, Bild 1 von 1
    • Flip laptop over to show backplate.
    • Loosen and remove modem card screw using a Phillips #1 screwdriver.
    • Remove modem card.
  23. Dell Inspiron 1420 Disassembly, Release Motherboard: Schritt 23, Bild 1 von 2 Dell Inspiron 1420 Disassembly, Release Motherboard: Schritt 23, Bild 2 von 2
    • Flip laptop over and gently pull motherboard away from backplate.
    • Disconnect the indicated connection to release the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 104
