Zum Hauptinhalt wechseln
Dell Inspiron 14R-N4010 RAM Replacement
Cory Ringley
Cory Ringley und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 15, 2017
25 - 30 Minuten
Mittel
Empfohlene Anleitung von Studierenden
Removing and replacing RAM is very straightforward on this device. The manufacturer designed the system to make access to the RAM very easy and as such, will not take long to do.
Was du brauchst
Ersatzteile
Werkzeuge
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Mehr anzeigen …
  1. Dell Inspiron 14R-N4010 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron 14R-N4010 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14R-N4010 RAM Replacement: Schritt 2, Bild 2 von 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron 14R-N4010 RAM Replacement: Schritt 3, Bild 1 von 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron 14R-N4010 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Using the #0 Phillips-Head screwdriver, unscrew the screw holding the RAM cover on.
    • The screw will not come all the way out.
  5. Dell Inspiron 14R-N4010 RAM Replacement: Schritt 5, Bild 1 von 1
    • Once the RAM cover is free use your hand to pull from the side with the screw: UP and OUT to remove the RAM cover.
  6. Dell Inspiron 14R-N4010 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 14R-N4010 RAM Replacement: Schritt 6, Bild 2 von 2
    • Place the plastic spudger on the metal clips and push them out to the side.
    • Once you have done this with both sides, the RAM should pop up to a 45 degree angle.
  7. Dell Inspiron 14R-N4010 RAM Replacement: Schritt 7, Bild 1 von 1
    • To release the RAM pull it out linearly to how it is in. Pull it straight back until it releases.
    • Repeat as necessary for the lower RAM module.
Abschluss
To reassemble your device, follow these instructions in reverse order. Ensure that the RAM is fully seated into the slot and no gold contacts are visible.
2 weitere Personen haben diese Anleitung absolviert.
Cory Ringley
137 Reputation
1 Anleitung geschrieben
USF Tampa, Team S13-G5, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
FYI People, this Laptop Supports 16 GB of RAM i.e. two stick of 8 GB DDR3L 1.35v 1600Mhz. I am using this laptop with Ubuntu 19.10 now after that Upgrade.
Gaurav Sood - Antwort
Do you still have 16GB RAM on that N4010? Why do they recommend 8GB Max then….I hope it did not overheat on you
qban_damian -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,447
