Dell Inspiron 15 3568 Display Assembly Replacement
Einleitung
Zu Schritt 1 der AnleitungIn this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Werkzeuge
Turn the computer over and open the display as far as possible.
Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
Note the display cable routing and remove the cable from its routing guides on the computer base.
Remove the screws that secure the display hinges to the computer base.
Carefully lift the display assembly off the computer base.
Align the screw holes on the display hinges with the screw holes on the computer base.
Replace the screws that secure the display hinges to the computer base.
Route the display cable through its routing guides on the computer base.
Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
