Zum Hauptinhalt wechseln
Dell Inspiron 15 5577 Gaming Fans Replacement
Julia Cabral
Julia Cabral und 4 weitere Mitwirkende
Zuletzt aktualisiert am January 2, 2024
25 Minuten - 1 Stunde
Mittel
Benötigt Bessere Bilder
When your Dell laptop starts overheating or making strange fan noises, it may be time to consider a fan replacement. This replacement will improve heating issues, and protect your laptop from potential harm. Basic hardware skills are a must, along with having a gentle touch to navigate the disassembly process. Successfully swapping out the fan requires careful precision, making this repair a rewarding yet complex task for your Dell Inspiron 15 5577.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 15 5577 Gaming Fans Replacement, Fans: Schritt 1, Bild 1 von 1
    • Unscrew the base cover plate to locate the gaming fan.
  2. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 2, Bild 1 von 1
    • Remove the base cover.
  3. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 3, Bild 1 von 1
    • Gently tug on the battery cable in order to disconnect it from the motherboard.
  4. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 4, Bild 1 von 1
    • Loosen the screws that secure the battery in place.
  5. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the battery out of the laptop.
  6. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 6, Bild 1 von 1
    • Remove the cable above the hard drive.
  7. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 7, Bild 1 von 1
    • Loosen the screws that secure the hard drive.
  8. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the hard drive.
  9. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 9, Bild 3 von 3
    • Flip the laptop over and open the lid.
    • Remove the palm rest.
  10. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 10, Bild 1 von 1
    • Carefully unsecure the rest of the shell on the base of the computer.
  11. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 11, Bild 1 von 1
    • Remove the keyboard.
  12. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 12, Bild 1 von 1
    • Loosen the screws securing the metal plate and contents of the base.
  13. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 13, Bild 1 von 1
    • Remove the plate.
  14. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 14, Bild 1 von 1
    • Unscrew and remove the first fan from the base of the laptop.
  15. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 15, Bild 1 von 1
    • Remove the fan's cable from the board.
  16. Dell Inspiron 15 5577 Gaming Fans Replacement: Schritt 16, Bild 1 von 1
    • Repeat steps 14 and 15 for the remaining fan.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Julia Cabral
403 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S2-G7, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G7, Barthe Fall 2019
UMASSD-BARTHE-F19S2G7
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 50
Insgesamt: 2,420
