Zum Hauptinhalt wechseln
Dell Inspiron 15 7560 Battery Replacement
Terrence15
Terrence15 und 2 weitere Mitwirkende
Zuletzt aktualisiert am August 24, 2022
7 - 15 Minuten
Leicht
Anleitung eines Community-Mitglieds
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Fix Kit
Dieses Kit enthält alle Ersatzteile und Werkzeuge, die für die Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 15 7560 Battery Replacement, Disconnect the Battery Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15 7560 Battery Replacement, Peel the Tape: Schritt 2, Bild 1 von 1
    • Peel the tape that secures the hard-drive cable to the battery.
  3. Dell Inspiron 15 7560 Battery Replacement, Open the Latch: Schritt 3, Bild 1 von 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  4. Dell Inspiron 15 7560 Battery Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 7560 Battery Replacement, Lifting the Battery: Schritt 5, Bild 1 von 1
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Inspiron 15 7560 Battery Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Battery Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 7560 Battery Replacement, Sliding the Hard Drive Cable: Schritt 9, Bild 1 von 1
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
  9. Dell Inspiron 15 7560 Battery Replacement, Adhering the Tape: Schritt 10, Bild 1 von 1
    • Adhere the tape that secures the hard-drive cable to the battery.
  10. Dell Inspiron 15 7560 Battery Replacement, Connect the Battery Cable: Schritt 11, Bild 1 von 1
    • Connect the battery cable to the system board.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
Terrence15
79.555 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 4,695
