Zum Hauptinhalt wechseln
Dell Inspiron 15-3543 Keyboard Replacement
Brianna Blackburn
Brianna Blackburn und 2 weitere Mitwirkende
Zuletzt aktualisiert am May 30, 2023
7 Minuten
Mittel
Have all of the keys or some keys on the keyboard for your Dell Inspiron 15-3543 stopped working? If so, here is the guide to fix the problem by simply replacing your keyboard. All you need is the metal spudger tool in order to pry the keyboard up and remove the cable ribbon.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 32
Insgesamt: 1,194
