Dell Inspiron 15-3543 Touchpad Replacement
Einleitung
Zu Schritt 1 der AnleitungIs the touchpad in your Dell Inspiron 15-3543 not working properly, sticking down, or is unresponsive?
If so, here is the guide to fix the problem by simply replacing your touchpad. You will need the #0 Phillips screwdriver and opening tools, in order to remove the 19 screws involved with this replacement and pry the top panel from the bottom panel.
Was du brauchst
Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
Using a #0 Phillips screwdriver, remove the 2.0mm screw beside the black pull tab on the hard drive to the bottom left of the device.
Pull the black tab up and to the left to completely remove the hard drive.
Sit the hard drive to the side once it is out.
Turn the device over and open it.
You will see 5 notches at the top of the keyboard.
Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
After popping up the ribbon cable lock, you can pull the ribbon cable out and sit the keyboard to the side.
Push the two battery locks outwards.
Pull the top of the battery up and out.
Sit the bettery to the side once it is out.
Remove the following ten screws with a #0 Phillips screwdriver:
Two 8.0mm screws.
Eight 4.0mm screws.
Using a #0 Phillips screwdriver, remove the three 4.0mm screws on the front where the keyboard used to be.
On the front of the device, there will be two ribbon cables. Remove them using the following directions:
Pull the black cable ribbon lock up and pull the blue ribbon out using the tab.
Pull the white cable ribbon lock up and pull the blue ribbon out using the tab .
Using the one or two opening tools, pry the bottom of the top plate off starting underneath the headphone jack.
Continue going around the device and prying it open until the top panel is off.
On the inside of the top panel, pull the black ribbon cable lock up and pull the ribbon cable out using the tab.
2 weitere Personen haben diese Anleitung absolviert.
