Zum Hauptinhalt wechseln
Dell Inspiron 15-7567 Touchpad  Replacement
Dallas Lamorie
Dallas Lamorie und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 - 20 Minuten
Mittel
This may be needed if your touchpad is not working as it usually does.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 15-7567 Touchpad  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 2, Bild 2 von 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 3, Bild 1 von 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 4, Bild 2 von 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 6, Bild 1 von 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Touchpad  Replacement, Touchpad: Schritt 7, Bild 1 von 1
    • Remove the clip holding the power cord on the Touch Pad by using tweezers, your fingers, or iFixit removing tools to gently pull up on the clip.
    • This should release the power cord as shown.
  8. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 3mm screws using a Phillips #1 screwdriver in the locations shown.
  9. Dell Inspiron 15-7567 Touchpad  Replacement: Schritt 9, Bild 1 von 1
    • Remove Touch Pad by pulling towards you gently at a slight upward angle.
    • The Touch Pad is now removed and ready to be replaced.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 38
Insgesamt: 2,105
