Zum Hauptinhalt wechseln
Dell Inspiron 17-5748 Speakers Replacement
Bradley
Bradley und 4 weitere Mitwirkende
Zuletzt aktualisiert am June 26, 2018
10 - 20 Minuten
Mittel
This guide will show how to access and replace the speakers in this laptop. Simple tools are required. Be gentle when removing parts with ribbon cables.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: Schritt 4, Bild 1 von 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: Schritt 4, Bild 2 von 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: Schritt 4, Bild 3 von 3
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 7, Bild 3 von 3
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: Schritt 8, Bild 1 von 1
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 9, Bild 2 von 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 10, Bild 2 von 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 11, Bild 2 von 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: Schritt 12, Bild 1 von 1
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: Schritt 13, Bild 1 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 13, Bild 2 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 13, Bild 3 von 3
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 17-5748 Speakers Replacement: Schritt 14, Bild 3 von 3
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 15, Bild 2 von 2
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: Schritt 16, Bild 1 von 2 Dell Inspiron 17-5748 Speakers Replacement: Schritt 16, Bild 2 von 2
    • Using the plastic opening tool, gently remove the second speaker.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Bradley
235 Reputation
1 Anleitung geschrieben
Washington State, Team S2-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S2-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S2G2
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 24
Insgesamt: 630
