Zum Hauptinhalt wechseln
Dell Inspiron 17R-N7010 Motherboard Replacement
frank scott
frank scott und 7 weitere Mitwirkende
Zuletzt aktualisiert am May 16, 2022
20 - 40 Minuten
Mittel
This guide demonstrates how to replace the motherboard from your Dell Inspiron laptop (model #17R-N7010).
The motherboard is the main circuit board in the computer, which establishes connections between the various components, and allows communication between them.
The motherboard may need replaced if your computer experiences the following issues:
·        Frequent screen freezes
·        Programs failing to load
·        Blue screen of death/ boot failure
·        Not recognizing hardware (keyboard, mouse)
·        Physical damage to motherboard (burns, chips)
Before beginning this repair, make sure your laptop is turned off and disconnected from the power adapter.
Was du brauchst
Ersatzteile
Werkzeuge
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Mehr anzeigen …
  1. Dell Inspiron 17R-N7010 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: Schritt 3, Bild 1 von 3 Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: Schritt 3, Bild 2 von 3 Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: Schritt 3, Bild 3 von 3
    • Remove the four screws from the back panel.
    • Flip the laptop over and open it to view the keyboard.
    • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
  4. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Close the laptop and flip it over so the bottom is facing upwards.
    • Remove the two screws from the small panel.
    • Remove the small back panel.
    • Slide the CD drive out of the laptop.
    • Remove the three screws from the CD drive slot.
  5. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
    • Remove the top cover by inserting a spudger under the surface.
    • Working clockwise, pry upwards with the spudger to detach the clips.
  6. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the ribbon cables.
    • Remove the cover to access the inner hardware of the laptop.
  7. Dell Inspiron 17R-N7010 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Make sure the SIM card has already been removed. If not, remove it now.
    • Carefully unplug the four ports connecting to the computer (the prying tool may come in handy when using it on the ports).
  8. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove all 10 screws on the motherboard using the Phillips #0 screwdriver.
  9. Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 17R-N7010 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Carefully lift the motherboard at an angle, and slowly pull out the final port.
    • You will find the port on the bottom of the motherboard shown in the first picture.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 22
Insgesamt: 1,544
