Zum Hauptinhalt wechseln
Dell Inspiron 17R-N7010 Palm Rest Replacement
Brandon Lopez
Brandon Lopez und 9 weitere Mitwirkende
Zuletzt aktualisiert am May 16, 2022
20 Minuten
Mittel
This guide will cover how to replace the palm rest component of a Dell Inspiron 17R-N7010 computer and show how to access the inner hardware of the laptop, including but not limited to, the motherboard, fans, and processors.
Before using this guide, make sure that the computer is powered off and that you are in a clean and clear workspace where it will be easy to keep track of all parts.
This guide requires basic knowledge of how to use tools like a screwdriver and a spudger. Remember to take your time when using the spudger and to not rush. It may take longer but you will get the job done right if you take your time when attempting this guide.
Was du brauchst
Werkzeuge
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Inspiron 17R-N7010 Palm Rest Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 2, Bild 1 von 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: Schritt 3, Bild 1 von 3 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: Schritt 3, Bild 2 von 3 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: Schritt 3, Bild 3 von 3
    • Remove the four screws from the back panel.
    • Flip the laptop over and open it to view the keyboard.
    • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
  4. Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 4, Bild 3 von 3
    • Close the laptop and flip it over so the bottom is facing upwards.
    • Remove the two screws from the small panel.
    • Remove the small back panel.
    • Slide the CD drive out of the laptop.
    • Remove the three screws from the CD drive slot.
  5. Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 5, Bild 1 von 1
    • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
    • Remove the top cover by inserting a spudger under the surface.
    • Working clockwise, pry upwards with the spudger to detach the clips.
  6. Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17R-N7010 Palm Rest Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the ribbon cables.
    • Remove the cover to access the inner hardware of the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 709
