Zum Hauptinhalt wechseln
Dell Inspiron 3520 RAM Replacement
Ian
Ian und eine weitere beteiligte Person
Zuletzt aktualisiert am June 11, 2015
10 Minuten
Leicht
This repair process involves going into the computer, therefore,you will need to be gentle with electronic components. Also, consider working on this repair in a clean environment so no small pieces of the computer are lost.
Was du brauchst
Ersatzteile
Werkzeuge
  • Spudger
    Spudger
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Dell Inspiron 3520 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 3520 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 RAM Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 3520 RAM Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 3520 RAM Replacement: Schritt 2, Bild 3 von 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 RAM Replacement, Keyboard: Schritt 3, Bild 1 von 2 Dell Inspiron 3520 RAM Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 3520 RAM Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 RAM Replacement, RAM: Schritt 6, Bild 1 von 1
    • Locate the RAM chip(s)
    • There are no RAM chips present in this photo.
  7. Dell Inspiron 3520 RAM Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 3520 RAM Replacement: Schritt 7, Bild 2 von 2
    • There are two connecting pins for the lower chip.
    • There are two connecting pins for the upper chip.
    • Pull the pins away from the sides of the chip(s) to release it.
    • The chip(s) should slide away from the dock easily.
Abschluss
17 weitere Personen haben diese Anleitung absolviert.
Ian
1.557 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-2, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 58
Insgesamt: 32,652
