Zum Hauptinhalt wechseln
Dell Inspiron 3542 Heat Sink Replacement
Rachel lindsey
Rachel lindsey und 7 weitere Mitwirkende
Zuletzt aktualisiert am April 9, 2019
30 Minuten
Schwierig
Falsche Werkzeuge
Benötigt Mehr Bilder
Aus eins mach mehr
Follow these steps to disassemble the computer, access the heat sink, and replace the part.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: Schritt 1, Bild 1 von 2 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: Schritt 1, Bild 2 von 2
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 3542 Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 4, Bild 3 von 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 5, Bild 3 von 3
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 3542 Heat Sink Replacement: Schritt 6, Bild 2 von 2
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 7, Bild 3 von 3
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: Schritt 8, Bild 1 von 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: Schritt 9, Bild 1 von 1
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: Schritt 10, Bild 1 von 1
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 3542 Heat Sink Replacement: Schritt 11, Bild 2 von 2
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: Schritt 12, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 12, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 12, Bild 3 von 3
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: Schritt 13, Bild 1 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 13, Bild 2 von 3 Dell Inspiron 3542 Heat Sink Replacement: Schritt 13, Bild 3 von 3
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Rachel lindsey
733 Reputation
5 Anleitungen geschrieben
Texas Tech, Team S46-G1, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 24
Letzte 30 Tage: 44
Insgesamt: 1,531
