Zum Hauptinhalt wechseln
Dell Inspiron 530 DCMF Fan Replacement
Drew Cunningham
Drew Cunningham und 6 weitere Mitwirkende
Zuletzt aktualisiert am June 14, 2021
20 Minuten
Mittel
Action Shots
Benötigt Mehr Bilder
Fehlende Angaben
If you have noticed that your Dell Inpiron 530 DCMF has been over heating or if you know the fan is broken, this guide will help you replace the unit’s fan.
The main fan keeps then interior of you computer from overheating, which ultimately leads to your computer more efficiently. Sometimes the fan can get clogged with dirt and just needs a simple cleaning. However, if you have noticed that the fan has stopped functioning or is noticeably damaged, following this guide will lead to a quick and easy fix for this issue.
Before you begin the disassembly process, make sure your computer is completely turned off, as it could be damaging to the computer working on it while it’s on.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 530 DCMF Fan Replacement, Fan: Schritt 1, Bild 1 von 2 Dell Inspiron 530 DCMF Fan Replacement, Fan: Schritt 1, Bild 2 von 2
    • Unscrew the two large screws on the back that are securing the side panel.
    • Slide the panel backwards to remove it.
  2. Dell Inspiron 530 DCMF Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 530 DCMF Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the four screws on the outside of the case that hold the fan in place.
  3. Dell Inspiron 530 DCMF Fan Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 530 DCMF Fan Replacement: Schritt 3, Bild 2 von 2
    • Unplug the fan connector from the motherboard.
  4. Dell Inspiron 530 DCMF Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the fan from the device.
    • Now you can clean out the fan using a cloth, paper towel or compressed air. Or you can install a new fan.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 5-1, Kish Spring 2015 Mitglied von UMass Dartmouth, Team 5-1, Kish Spring 2015
UMASSD-KISH-S15S5G1
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 942
