Zum Hauptinhalt wechseln
Dell Inspiron 8600 Upper Case Replacement
John Nesthus
John Nesthus und 6 weitere Mitwirkende
Zuletzt aktualisiert am January 28, 2014
5 Minuten
Leicht
Action Shots
Benötigt Mehr Bilder
Falsche Werkzeuge
Fehlende Schritte
We will show you how to remove the display module which will then allow you to remove the upper case.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 8600 Upper Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: Schritt 2, Bild 1 von 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: Schritt 2, Bild 2 von 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: Schritt 2, Bild 3 von 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Upper Case Replacement: Schritt 3, Bild 1 von 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Upper Case Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Upper Case Replacement, Display Module: Schritt 5, Bild 1 von 2 Dell Inspiron 8600 Upper Case Replacement, Display Module: Schritt 5, Bild 2 von 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Upper Case Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Upper Case Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 8600 Upper Case Replacement: Schritt 7, Bild 2 von 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Upper Case Replacement: Schritt 8, Bild 1 von 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Upper Case Replacement, Upper Case: Schritt 9, Bild 1 von 2 Dell Inspiron 8600 Upper Case Replacement, Upper Case: Schritt 9, Bild 2 von 2
    • Remove the two screws that hold the upper case.
    • You can now pop up the upper case and replace.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
John Nesthus
186 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 18-22, Garner Spring 2011 Mitglied von Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,600
