Zum Hauptinhalt wechseln
Dell Inspiron 9300 Keyboard Replacement
Ady Alhamra
Ady Alhamra und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 25, 2017
5 - 15 Minuten
Mittel
We've all had a similar problem: The keyboard loses a key, something doesn't work with it, etc. While the Inspiron 9300 from Dell has aged, the durability and longevity of the device has still proven itself to old users and new users alike.
This quick guide will show you how to replace a faulty keyboard in the Dell Inspiron 9300.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
    • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
  2. Dell Inspiron 9300 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5mm Phillips screws holding the keyboard in place.
  3. Dell Inspiron 9300 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the keyboard away from the laptop.
    • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
  4. Dell Inspiron 9300 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 9300 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the blue tab to disconnect the keyboard.
    • Pull the keyboard up and away to safely remove the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ady Alhamra
149 Reputation
1 Anleitung geschrieben
USF Tampa, Team 16-6, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 535
