Dell Inspiron 9300 WIFI Card Replacement
Einleitung
Zu Schritt 1 der AnleitungThis content will describe the procedure for replacing the WIFI Card.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Flip the computer over and place it on a clean level surface.
Loosen the screws using a size #0 Phillips screwdriver.
Once the screws are loose, open the panel using a plastic opening tool to access the components below.
Gently pry up on the gold antennae connections using a spudger.
Gently pry open both retaining clips on either side of the WiFi card using a spudger.
Eine weitere Person hat diese Anleitung absolviert.
