Zum Hauptinhalt wechseln
Dell Inspiron E1405 Heat Sink Replacement
Sarah Neal Secrest
Sarah Neal Secrest und 2 weitere Mitwirkende
Zuletzt aktualisiert am May 25, 2017
10 Minuten
Mittel
This guide will help you replace the heat sink in a Dell Inspiron 1305.
Was du brauchst
Werkzeuge
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron E1405 Heat Sink Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron E1405 Heat Sink Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: Schritt 3, Bild 1 von 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: Schritt 3, Bild 2 von 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: Schritt 3, Bild 3 von 3
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron E1405 Heat Sink Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron E1405 Heat Sink Replacement: Schritt 4, Bild 3 von 3
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
Abschluss
Texas Tech, Team S8-G3, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 248
