Zum Hauptinhalt wechseln
Dell Inspiron M531R-5535 Fan Replacement
Tony Chen
Tony Chen und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 28, 2022
30 - 50 Minuten
Schwierig
Use this guide to replace the fan in your Dell Inspiron M531R-5535 laptop.
The fan is an essential component for preventing the computer from overheating. The fan allows the computer hardware to cool off and make the computer more smoothly.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Was du brauchst
Werkzeuge
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mehr anzeigen …
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 2, Bild 2 von 2
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 4, Bild 2 von 2
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 5, Bild 2 von 2
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 3 von 3
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 8, Bild 2 von 2
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 9, Bild 2 von 2
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: Schritt 11, Bild 1 von 1
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Tony Chen
310 Reputation
2 Anleitungen geschrieben
CSU Los Angeles, Team 6-5, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-5, Adachi Fall 2022
CSULA-ADACHI-F22S6G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 11
Insgesamt: 252
