Zum Hauptinhalt wechseln
Dell Inspiron Mini 10 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it up and out.
    Frag FixBot
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: Schritt 3, Bild 1 von 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
    Frag FixBot
  4. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
    Frag FixBot
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
    Frag FixBot
  6. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
    Frag FixBot
  7. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
    Frag FixBot
  8. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
    Frag FixBot
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: Schritt 9, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: Schritt 9, Bild 2 von 2
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
    Frag FixBot
  10. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
    Frag FixBot
  11. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team 1-4, Rose Fall 2016 Mitglied von UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
On at least one Dell Inspiron 10 (mine), the hard drive is also secured by adhesive foam backing to the back cover of the laptop. This makes it impossible to remove by the method in this guide (and the service manual) without first either A) heating the back cover with a heat pad, or B) removing the palm rest bracket covering the mainboard, disengaging the clips that prevent the hard drive from being pulled upward, then prising the drive gently away from the backing. This also requires you to bend the hard drive screw bracket, but being aluminum, it can be bent back at least once. I used method B.
Anthony Stvartak - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 57
Insgesamt: 8,438
