Zum Hauptinhalt wechseln
Dell Inspiron N4010 Fan  Replacement
Andre Tomlinson
Andre Tomlinson und 3 weitere Mitwirkende
Zuletzt aktualisiert am 15. Dez 2017
20 - 25 Minuten
Mittel
This guide will show you how to completely remove and replace the fan on your Dell Inspirion 14R. It requires a bit of patience to accomplish. Replacement of the single internal fan can cause your laptop to run less hot as it is responsible for keeping everything inside the laptop, especially the CPU, cool.
Was du brauchst
Werkzeuge
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
Mehr anzeigen …
  1. Dell Inspiron N4010 Fan  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Fan  Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement: Schritt 2, Bild 2 von 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Fan  Replacement: Schritt 3, Bild 1 von 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Fan  Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron N4010 Fan  Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron N4010 Fan  Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Fan  Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Fan  Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement: Schritt 7, Bild 2 von 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Fan  Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement: Schritt 8, Bild 2 von 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Fan  Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement: Schritt 9, Bild 2 von 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Fan  Replacement, Palm Rest Assembly: Schritt 10, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement, Palm Rest Assembly: Schritt 10, Bild 2 von 2
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Fan  Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement: Schritt 11, Bild 2 von 2
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Fan  Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Fan  Replacement: Schritt 13, Bild 1 von 1
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right.
  13. Dell Inspiron N4010 Fan  Replacement, Fan: Schritt 14, Bild 1 von 2 Dell Inspiron N4010 Fan  Replacement, Fan: Schritt 14, Bild 2 von 2
    • Peel back the yellow tape to expose the ribbon connector.
    • Unplug the ribbon cable from the motherboard.
  14. Dell Inspiron N4010 Fan  Replacement: Schritt 15, Bild 1 von 1
    • Unplug the 3-wire connector from the motherboard.
  15. Dell Inspiron N4010 Fan  Replacement: Schritt 16, Bild 1 von 1
    • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
  16. Dell Inspiron N4010 Fan  Replacement: Schritt 17, Bild 1 von 1
    • Remove the fan from the device.
Abschluss
Rüste dich für deine nächste Reparatur
Alle in den Warenkorb legen
USF Tampa, Team S13-G5, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 1,191
