Zum Hauptinhalt wechseln
Dell Inspiron N5050 Hard Drive Replacement
Kristy Mayo
Kristy Mayo und 2 weitere Mitwirkende
Zuletzt aktualisiert am November 15, 2022
10 - 15 Minuten
Mittel
Before disassembling this device further, have a screwdriver and a plastic opening tool nearby. This section of the guide involves removing the keyboard, so make sure you carefully pull the keyboard cable to prevent damaging it.
Was du brauchst
Komplettpaket für die Reparatur
Diese Kits enthalten alle Ersatzteile und Werkzeuge, die für diese Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Slide the hard drive right and up to remove it from the laptop.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
Kristy Mayo
1.508 Reputation
3 Anleitungen geschrieben
4 Kommentare
Thanks again. This guide was made straightforward and clear.
jason acn - Antwort
Thanks you - The clear instructions make this guide easy to follow.
Jay - Antwort
wouldnt turn on after i re-assembled it
Taemon Coolz - Antwort
Sehr gute Arbeit
pouchman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 38
Insgesamt: 7,067
