Zum Hauptinhalt wechseln
Dell OptiPlex 9010 CPU Fan Replacement
Abhiraj Khinda
Abhiraj Khinda und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 20, 2025
15 - 30 Minuten
Mittel
Fehler in den Markups
If you have issues with your computer overheating, generating loud noises, or crashing frequently, it may have a problem with your CPU fan.
The CPU cooling fan prevents your computer from overheating and slowing down. Replacing your PC's old fan will help prolong the lifespans of your CPU and Dell OptiPlex 9010.
Follow this guide if you need to replace the CPU fan of your Dell OptiPlex 9010.
Before you begin, turn off your computer and unplug it from the outlet.
Was du brauchst
Werkzeuge
  1. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: Schritt 1, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: Schritt 1, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: Schritt 1, Bild 3 von 3
    • Ensure the PC is physically unplugged before beginning any disassembly procedures!
    • Place the PC on a flat surface.
    • Turn the PC over so that the panel side faces upward.
  2. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 2, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 2, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 2, Bild 3 von 3
    • Use your hand to lift the handle upward to access the hardware.
  3. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 3, Bild 1 von 2 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 3, Bild 2 von 2
    • Locate the CPU fan.
    • Locate the fan header (where the cords connect the fan to the motherboard).
  4. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 4, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 4, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 4, Bild 3 von 3
    • Unplug the fan header by pressing the tab on the side of the connector and pulling upward.
  5. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 5, Bild 1 von 2 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 5, Bild 2 von 2
  6. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 6, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 6, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 6, Bild 3 von 3
    • After disconnecting the fan from the frame, carefully lift the fan up.
  7. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 7, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 7, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 7, Bild 3 von 3
    • Align the new fan over the four screws you previously removed.
    • Insert the new fan header into the socket.
  8. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 8, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 8, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 8, Bild 3 von 3
    • Ensure the fan is correctly aligned with the four screw holes.
    • Replace and tighten screws using the Phillips #1 screwdriver.
  9. Dell OptiPlex 9010 CPU Fan Replacement: Schritt 9, Bild 1 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 9, Bild 2 von 3 Dell OptiPlex 9010 CPU Fan Replacement: Schritt 9, Bild 3 von 3
    • The replacement of the Dell Optiplex 9010 Fan has been complete!
    • Place the access panel back on to secure the inner hardware.
Abschluss
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
Eine weitere Person hat diese Anleitung absolviert.
Abhiraj Khinda
196 Reputation
1 Anleitung geschrieben
York University, Team 1-16, O'Regan Summer 2023 Mitglied von York University, Team 1-16, O'Regan Summer 2023
YORK-O'REGAN-SU23S1G16
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 446
