Zum Hauptinhalt wechseln
Dell Precision 5540 Fans Replacement
Nick Panin
Nick Panin und 2 weitere Mitwirkende
Zuletzt aktualisiert am July 13, 2023
Keine Schätzung
Leicht
Aufzählungszeichen!
Anleitung eines Community-Mitglieds
Replacing CPU fan P/N: 0F01PX
and GPU fan P/N: 0V9H8N
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect your computer from all the cables.
  1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: Schritt 2, Bild 1 von 2 Dell Precision 5540 Fans Replacement, Remove the base cover screws: Schritt 2, Bild 2 von 2
    • Close the display lid and turn the computer over.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
  2. Dell Precision 5540 Fans Replacement, Remove the base cover: Schritt 3, Bild 1 von 2 Dell Precision 5540 Fans Replacement, Remove the base cover: Schritt 3, Bild 2 von 2
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    • Two case latches are approximately here.
  3. Dell Precision 5540 Fans Replacement, Remove battery plug: Schritt 4, Bild 1 von 1
    • Here.
    • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
  4. Dell Precision 5540 Fans Replacement, Remove CPU fan: Schritt 5, Bild 1 von 1
    • Unplug the fan cord.
    • Note the dot on the fan power socket which mark the upper side.
    • Unscrew M2 screws.
  5. Dell Precision 5540 Fans Replacement, Remove GPU fan: Schritt 6, Bild 1 von 1
    • Unscrew M2 screws
Abschluss
Nick Panin
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 660
