Einleitung
This guide shows how to remove and replace the battery for the Dell XPS 13 9300 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ersatzteile
If you use BitLocker, make sure to have your Recovery Key written down.
Use a Torx T5 screwdriver to remove the eight screws that secure the base cover to the palm-rest and keyboard assembly
Starting from the bottom-left corner, use a spudger to pry the base cover in the direction of the arrows to release the base cover from the palm-rest and keyboard assembly.
Hold both sides of the base cover and lift to remove the base cover from the laptop.
Use a Phillips screwdriver to remove the five screws securing the battery.
Lift and remove the battery.
Hold the laptop's power button down for 15 seconds to drain any residual power from the laptop.
Ein weiterer Nutzer hat diese Anleitung absolviert.
