Zum Hauptinhalt wechseln
Dell XPS 15 9570 Keyboard Replacement
Sophie
Sophie und 5 weitere Mitwirkende
Zuletzt aktualisiert am April 15, 2024
2 Stunden
Mittel
Action Shots
Benötigt Mehr Bilder
Use this guide to learn the steps to remove the keyboard of your Dell XPS 15 9570. The keyboard is an input device used to enter characters and functions into your computer system by pressing the keys.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell XPS 15 9570 Keyboard Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Keyboard Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Keyboard Replacement, Heat Sink: Schritt 8, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, Heat Sink: Schritt 8, Bild 2 von 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Keyboard Replacement, Fan: Schritt 10, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, Fan: Schritt 10, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Keyboard Replacement: Schritt 11, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Keyboard Replacement: Schritt 12, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Keyboard Replacement: Schritt 13, Bild 1 von 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Keyboard Replacement, RAM: Schritt 14, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, RAM: Schritt 14, Bild 2 von 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Keyboard Replacement: Schritt 15, Bild 1 von 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Keyboard Replacement, SSD: Schritt 16, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, SSD: Schritt 16, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Keyboard Replacement: Schritt 17, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 17, Bild 2 von 2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Keyboard Replacement, Wireless Card: Schritt 18, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, Wireless Card: Schritt 18, Bild 2 von 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Keyboard Replacement: Schritt 19, Bild 1 von 1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Keyboard Replacement: Schritt 20, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 20, Bild 2 von 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Keyboard Replacement: Schritt 21, Bild 1 von 1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Keyboard Replacement, Keyboard: Schritt 22, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement, Keyboard: Schritt 22, Bild 2 von 2
    • Disconnect the two motherboard cables using the opening tool.
  23. Dell XPS 15 9570 Keyboard Replacement: Schritt 23, Bild 1 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 23, Bild 2 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 23, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Keyboard Replacement: Schritt 24, Bild 1 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 24, Bild 2 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 24, Bild 3 von 3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Keyboard Replacement: Schritt 25, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 25, Bild 2 von 2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  26. Dell XPS 15 9570 Keyboard Replacement: Schritt 26, Bild 1 von 2 Dell XPS 15 9570 Keyboard Replacement: Schritt 26, Bild 2 von 2
    • Disconnect the keyboard cables, labeled BL and KB, using the opening tool.
  27. Dell XPS 15 9570 Keyboard Replacement: Schritt 27, Bild 1 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 27, Bild 2 von 3 Dell XPS 15 9570 Keyboard Replacement: Schritt 27, Bild 3 von 3
    • Unscrew the 1.9mm screws using a Phillips #00 screwdriver.
    • Flip the cutouts on the keyboard to reveal and unscrew remaining 1.9mm screws underneath.
    • Remove the keyboard.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Sophie
301 Reputation
2 Anleitungen geschrieben
IUPUI, Team 3-1, Harley Fall 2023 Mitglied von IUPUI, Team 3-1, Harley Fall 2023
IUPUI-HARLEY-F23S3G1
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Thanks alot.
Motherboard: 2 more cables to disconnect.
Keyboard backside some more screws to remove.
Mister Iks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 30
Letzte 30 Tage: 98
Insgesamt: 1,401
