Zum Hauptinhalt wechseln
Desktop PC Left Panel Replacement
David Lennon
David Lennon und 11 weitere Mitwirkende
Zuletzt aktualisiert am August 25, 2024
1 - 2 Minuten
Leicht
Removing the left panel of a desktop computer is an important skill to have for repair and troubleshooting purposes. The left panel must be removed before any repairs can be performed on the inside of the computer. In addition, computers with heating problems could benefit from having the left panel removed.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Desktop PC Left Panel Replacement, Left Panel: Schritt 1, Bild 1 von 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Left Panel Replacement: Schritt 2, Bild 1 von 2 Desktop PC Left Panel Replacement: Schritt 2, Bild 2 von 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Abschluss
24 weitere Personen haben diese Anleitung absolviert.
David Lennon
10.108 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 4-5, Maness Spring 2015 Mitglied von Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Mitglieder
45 Anleitungen geschrieben
3 Kommentare
What is the name of the case used in this tutorial?
Nicolas Hunter - Antwort
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Antwort
I have this same case in black and want to know what model it is.
numanair - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 68
Letzte 30 Tage: 247
Insgesamt: 6,723
