Einleitung
RAM(Random Access Memory) is a very fast type of memory. It stores short term information so that it can be accessed quickly. Replacing or upgrading RAM in a computer can help a computer run more quickly and smoothly.
Was du brauchst
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
- When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
50 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
very interesting
how to determine the speed
how can i differentiate between types of rams
