Zum Hauptinhalt wechseln
DigiLand DL801W Microphone Replacement
Travis Mangum
Travis Mangum und 3 weitere Mitwirkende
Zuletzt aktualisiert am September 24, 2018
30 Minuten
Schwierig
Benötigt Mehr Bilder
This guide will walk you through the process of replacing your DigiLand Dl801W microphone. Be careful as you complete the steps listed in this guide. If a component is not coming out smoothly, make sure that all screws that need to be removed were removed.
Note: Light soldering is required for successful repair of the microphone of the DigiLand Dl801W.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. DigiLand DL801W Microphone Replacement, Microphone: Schritt 1, Bild 1 von 1
    • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Microphone Replacement: Schritt 2, Bild 1 von 1
    • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
    • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Travis Mangum
572 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-4, Harley Fall 2015 Mitglied von IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 360
